1 - 9 of 9 Posts
I have a shop who is willing to make custom plate mounts for side mounted license plates if anyone is interested. I am trying to get them a series of M50 owners, only problem is that I do not have access to my M to get the rear tire shaft diameter to get to them. If anyone can help me with this I would be greatly appreciated. And if anyone on the forums makes these please let me know, I would love to help out forum members first.
The top Allen bolt it just about made for this and is a 19mm- 3/4". Side plate brackets are available on ebay for about $20. NMc
With the 3/4" will I be needing to drill it out, or will it fit in tight enough as is. I can have the shop mill it to a 19mm if need be, but just want to make sure so that I don't have to mess up a paint job.
I'm pretty sure that the side mount plates come with a 3/4" hole already in them and that you don't need any modifications to use them. I don't use one so you will have to wait for somebody else to post that can say for sure or find one on this site and send them a PM. NMc
Ok I will take a look into my Repair manual i assume they will have the diameter in there. Thanks for the info though.
Pull the chrome nut above and in front of the axle bolt cover, and measure the sholder on it. NMc
or you can do what i did, buy one for a harley and just make the hole bigger with a dremel. took about 10 min (i went slow so i didnt make it too big) and it was free.
1 - 9 of 9 Posts
