hello everyone, newbe here
i have a 1980 xl250s that i recently put a ney piston and rings in.
the piston was a pop top piston and now it spark knocks bad.
is there anything i can change on the firing to help it and if so can you tell me how.
thanks
Premium Member
Did you change the compression? How is the timing set on that bike?
Welcome.
yes the compression did change and the timming is set to factory , this all new to me. if it were a briggs it would be no prob, but a little different for me
then retard the timing by a bit. no idea by how much you'd need to do that, so just do a bit at a time until it goes away.
:plus1:
That's really your only option.....since there is no way now to drop the compression back down. The fact that hi-octane fuel helps pretty much proves this. In some parts of the country, hi-octane racing fuel is available.....if you search hard enough. IIRC, it runs about 105-110.
Long shot:
Put in a colder plug.
