On my short ride today, my speedometer stoped working. I decided to head back since the weather was looing a bit iffy, and then ran my hand up the cable to see if it was attached to the speedo. It seemed that the connection was loose since I could tighten it by hand, which I did. Unfortunately it started raining so I have no idea if it fixed the problem or not.
The one thing I did notice was that I got a lot of black grease on my fingers. Even if tightening it did solve the problem, will the lose of grease be something should be concerned about? If it didn't solve the problem, any suggestions before I take it to a shop?
I should mention that at some point before I got the bike it was clearly dropped and the speedometer took a hit. I can pull the trip milage reset knob out of the speedo, and the reset function does not work. In addition while the trip milage counter works, is at somewhat of an angle (not perfectly parallel to the odometer above it)
