I replaced the mainjet and pilot jet in the carb. There is an adjustable needle next to the pilot jet but the service manual does not cover the adjustment, nor even discusses the needle assembly. Anyone know how to adjust this particular needle? I will try to post a pic with this post. In the pic it is the needle on the far right next to the pilot jet.
Not sure what that jet is...if it is a jet...sure its not the idle pickup? My only suggestion is get hold of a microfiche exploded view for your particular model..it will most likely tell you what it is and you can go from there. Failing that a specific forum may be able to help.
Probably the idle air mix screw,I would seat it (gently) and back it out about 3/4 turn then start the bike and turn it in or out a little to find the high idle point.
