1 - 20 of 32 Posts
Suzuki Bandit running problem, can someone help?
Im having a problem with my bike so ill list all the infor
2001 Suzuki Bandit 600
4 cylinder, 4 carburator
Just changed the spark plugs
I was going to ride to work and after about a mile of riding i noticed my RPMs were falling. At a stoplight it seemed like the bike was going to stall, I had to hold the revs up to keep it from stalling. I pulled over to the side to play with it and when i let go of the gas the bike stalled. I tried restarting, no luck. I tried playing with stuff, no luck. I ended up waiting about 5-10 minutes calling insurance to get it towed. I tried starting up my bike and it ran fine! I drove a little less than a mile and started having the problem again, so i puleld over and same problem. I decided to drive it home, and waited 10 minutes and it started again. Sure enough the problem came back so i just held the throttle so it wouldnt die till I got home. Even then soemtimes it wasnt responsive to gas while accelerating from a slow speed.
I jsut had the bike for a regular service, so i would expect them to have found something obvious wrong.
I had had problems before i got it serviced that i think stemmed from having the bike sit for 2 months while not being driven. The people at the service station didnt report anything.
There is enough oil.
The battery turns over just fine, doesnt seem electrical.
Ill list the other things ive tried
Tried running it with the gas cap open to see if there was a vacume problem, but it didnt help.
Added seafoam to the gas, no help.
The petcock didnt seem dirty at all
I did a number of things today.
I checked the air filter, clean
Then i pulled out the carburetors and i opened up the top and bottom, checking the float, the little plunger attached to the float, that long needle that is attached to the diaphram on the top. I didnt pull out all the screws, i just puleld out the mainjet and inspected them. Clean. The other recessed small one i didnt have a screwdriver that would fit. Well one was too skiny and wouldnt turn the screw well.
The insides all appeared clean, couldnt find any gunk/residue/slime/anything. I put it all back together put the tank back on, started it up and let it run. The motor sounded slightly different. Maybe a little bit rougher but nothing bad. Sure enough the problem surfaced after a few minutes of being on.
I checked the spark plugs, slightly black but im guessing thats normal?
Important thing i found. As i was reading through my manual for any other ideas i saw a picture of a hose I had always wondered about. The picture said it was a drain hose and you remove the plug to let any water drain out. This hose comes from the air box. The section was talking about air filter cleaning. So i figured what the heck, ill go open it.
So i find it and open it and this liquid comes out pretty fast. I plug it back up and get a cup to catch it. I let it drain and i would say all in all abou 3/4 of a cup of this liquid came out. It is amber in color, smells a little bit like fuel but not completely, is to viscious to be oil or transmission fluid. Dirty liquid i think, had a small amount of sand like stuff inside too. Maybe a mixture of water and gasoline? It doesnt seem to evaporate real fast either, there is still some residue on the ground. I clean some of it off the ground with a paper towel, then to figure out what the liquid is i folded up the paper towel and lit it on fire. It caught fire taking about 5-10 seconds before the fire spread to the whole paper towel. It gave off a black smoke, and i had to stamp it out.
Gasoline would burn faster wouldn it?
So not sure what the fluid is but im hoping that was somehow the cause of my problems. Ill go start the bike and see what i can find...
EDIT:
I turned the bike on and let it run. After a few minutes the problem resurfaced. Surely that liquid isnt supposed to be there but i thought draining it would have solved my problem... darn...
Help is much appreciated.
I see only 2 probable causes:
Something in the ignition is heat sensitive
OR
Your are effectively running out of gas.
Since you can reproduce the problem in the garage, get a can of starting fluid (ether). When it starts to stumble, spray a very short squirt into the air box. If it picks up (runs better for a few seconds) you know your problem is fuel. My guess is that fuel IS the problem.
This test is not fool proof, however, since the problem could be getting too much fuel in one (or more) cylinder. If that is the case, I think the ether would have little effect, just like it would if there was an ignition problem.
One thing at a time!
OR
Ok, sounds like a good way. Starting fluid? is that different from gas?
And where do i spray it into the air box?
Heat seams like a possible problem. Im guessing the 5-10 minute cool down lets whatever defective part cool down enough. Maybe water is condensing as it cools back down and it can run again?
If the bike set for two months, I more think it may be a fuel problem. I am guessing sticking floats. I would recommend a good carb cleaning and adjustment.
I had got it running and drove it around a few times a week for at least a month before i took it in for service. The floats didnt seem at all stiky when i took apart the carbs and checked them out.
Serious carb work i would have to leave to the professionals. Thanks though.
This sounds like oil mixed with water and debris from your air filter. It definatley should not be in there and I would take it back to the dealer you got it serviced at and inform them of the stalling and the liquid from the air filter housing drain. There are several reasons why oil gets into a filter one being badly worn bores/rings/pistons. This depends upon how much mileage and attention your bike has. You may have had the oil overfilled also and this would cause a similar thing. Post back and tell us more re the stalling...does smoke come from the exhaust.... has the bike been dropped...what was done on the service etc.... You mention the plugs being slightly black...how black...this could indicate a rich mix...check your choke cable...I am assuming the set up for the 600 is the same as my 1200...the choke may be jammed on. Another point is the vacuume pipe for the fuel feed...make sure its not crimped under the tank. The final point is to take it for a run at high throttle and kill the engine then pull the plugs dark fluffy deposits = rich white powdery = lean and slimey black = worn bores/pistons/rings (possibly)...easy to say but a little harder to accomplish as the tank has to come off. This is called a plug chop and is the only reliable way to tell your fuel mix status.
Steve
Some other points I forgot to ask. Where do you park your bike, does it get wet, and did it rain heavily at all during the 2 month storage. Another point is if it sat for two months did you run it at all. I understand your fuel has alcohol added and this can play havoc with fuel systems. Also check very carefully all lines and filter bowels etc for water in the fuel, also your tank.... worthwhile draining it and refilling with fresh gas I reckon. One final thing is seafoam in the gas may just clear a tiny blockage that might be a problem. I have never use the stuff but others on the forum swear by it.
Well, maybe this wasn't such a good suggestion after all. :roll:
OK.........
Starting fluid is ether. HIGHLY volitile. Comes in a spray can.
Remove the air filter and aim the nozzle toward where the air filter WAS.
Only a VERY small amount required; 1/2 sec. spray or less.
P.S. It will be easier on us and you too if you don't post the exact SAME question in more than one thread at the same time.:mrgreen:
You now have responses in TWO different places.
Discussion Starter #8
Im pretty sure the drain hose isnt plugged, i even ran the motor with the tank cover open.
I park it under a garage.
I did not run it for that 1.5 - 2 month period, but had put a few hundred miles on the bike since that happened and it was serviced.
The service was a general service where they tighten all the bolts and check everything. About $350
The spark plugs were slightly blackened, a thin layer that rubbed off with a peper towel.
Yes hawaii fuel does have ethanol, but i only buy premium.
The liquid that drained out of the air box wasnt oil, it was rather thin and didnt feel like oil, and i would be able to tell if it was mixed with water because of the way water and oil mix... or dont.
Pistons, i would have to take it to the service station.
The oil is above the full line but the service station did this and it ran for about 200 miles after it was surviced with no problems, except maybe for vapor lock. Sometimes when i try to start the bike the engine turns a little bit then gets stuck, i have to roll the bike and let out the clutch to losen the engine.
Bike has been dropped but never hard. It was at like 1 mph and i was able to slow the drop so there wasnt really any damage, and that was a long time ago.
Choke seems fine, ive been able to use it.
Havent tried fresh gas, though the gas in there cant be older than a few weeks. Well at least a few weeks since the problem first came up.
I don't like the sound of the engine seeming to get stuck and rolling the bike to loosen it. This sounds like mechanical damage. From the sound of your primary problem you may be starved of oil. The engine runs first up then begins to loose power and finaly stalls. Does it get very hot?
I would definatly take it somewhere and get a proffessional opinion before going any further. Is the oil filter correctly fitted? Check oil is actually being pumped round the engine. I cannot think it is this but from the sound of the motor getting stuck it has to be something serious.
This model is not water cooled is it. If this is the case perhaps the head gasket is blown and coolant is getting into the oil. Check the oil for contamination ditto the coolant. I can't think of many other things it could be and without seeing the bike eyes on so to speak its difficult to give an accurate diagnosis. If it were mine I would take it to a Suzuki dealer and let them fool with it. You say you took it to a service station for the regular service correct???
Post back and let us know how you go.
BTW I wasn't refering to the drain hose being plugged I mentioned the vacuum pipe for the fuel cut off valve.... its under the tank on the fuel valve itself and crimping this starves the engine of fuel due to little or no vaccum to the fuel supply.
Steve
Edit: How long do you have to crank the engine to get it to start? When you say the engine gets stuck are you sure its the engine and not the starter motor? How stuck is stuck? does it take a lot of effort to get the motor to turn using the gears? What mileage have you got on it?
Sorry about that.
So remove the filter and 1/2 sec of ether. Can i get this at a car parts store?
Yes.......in Hawaii, maybe.
It is generally used to help vehicles start in VERY COLD weather and, of course, you don't know what that really is! :mrgreen:
If you don't see it on the shelf, ask. I'm sure there isn't much demand in your neck of the woods.
Discussion Starter #12
After 5-10 minutes of being on it gets hot, though im not sure if its abnormally hot.
The engine getting stuck, could it be vapor lock?
The engine is not water cooled.
I heard that if you run it with the gas cap open and it runs fine then there is a vacume problem, but i tried that and it didnt help.
the bike ahs 40,000 miles
Ill press the starter, which i think is ok, and it will turn a little for a fraction of a sec and stop. If i repeat, same thing. I will have to roll the bike a foot or two and let the clutch out, then ill press the starter and it will turn a little bit, but i little bit more than before. Repeat this process a few times and then it will turn over freely. Then its jsut a matter of holding it down until the engine starts, which sometimes isnt long and sometimes is a few seconds and a little throttle play.
I hope that info heps.
I could add more seafoam, but its bad to add to much right?
Ok the starter motor seems to be the problem there, phew! (lucky you) To get back to the original problem your motor must be starving fuel this is the only thing that could cause the motor to die in the way you are explaining it. If it were electrical you would generally get some bad firing...misfires etc... and I would expect the bike to be hard to start. I suggest you pull the carbs and set everything up as per the manual then work back from there. As for the crud in the filter box there may be a problem with the oil breather valve or it may simply be because the service dude overfilled it. I do not suspect it is the cause of the problem however it may also be something to do with the carbs...after all they are fastened to it!
Keep us up to date and (hopefully) with help from the forum you will be able to fix whatever it is.
Steve
Ah, ha. Maybe there is another possibliliy. Maybe the battery is about to shoot craps. I STRONGLY suggest you get your battery and charging system checked before you do anything else. Not likely it is causing ALL the problems but there is an outside chance.
As for the Seafoam, it is (generally) not strong enough to clean a REALLY dirty carb. After the battery test (and maybe a new one), you should DRAIN THE GAS and put in fresh. If that doesn't help, then we can talk about "real" carb cleaners.
Actually ER might have got onto the real problem re the stuck motor...check the earth connection to your battery and the one to the starter motor and any other/all cables wires switches etc...
Discussion Starter #16
Im pretty sure the starter motor is fine. The stuck motor doesnt see to be electrical though because once i get the motor running, it will turn over just fine try after try, and that problem wont resurface till the bike has been sitting a few days.
I bought some starter fluid, ill try that out today. The guy at napa said blackened spark plugs could either be fuel problem, or wrong spark plugs or needing new wires. Wires havent been changed since new as far as i know. The battery behaves like a good battery should. It doesnt have that many miles on it. In fact even when the bike had sat for a few montths with no riding, the battery didnt behave like it was weak or anything.
As far as the oil, i guess i could let a little bit out till the level returns to normal.
What we are trying to tell you here is that the motor might NOT be sticking at all. It might not be getting enough voltage to do the job.
There are several possible causes for this:
WORN OR DIRTY BRUSHES is the most common cause of starter failure on old jap bikes. Whether or not it works at any given time depends on exactly where the comutator stops in relation to the brushes. There may be only 1 bad spot.
Loose or corroded main battery cables. Check both ends. This can be an intermittant problem too.
Intermittant battery failure. Not likely since it is new but not impossible.
Discussion Starter #18
Update.
Checked the spark plugs again at the advice of a NAPA dude. He said sometimes they might put in the wrong spark plug, there is standard, cold and hot. He said older bikes might need hot, so i checked the manual.
Standard: CR9EK Cold:CR10EK Hot: CR8EK
I pulled out a spark plug and it was labeled CR10EK. Hawaii doesnt usually get cold. Also the plug head was indead black and when i wiped it with a paper towel black stuff (carbon?) would wipe off, kind of powdery. It had a slight smell, possibly fuel.
I checked the drain hose comming from the air box again and to my surprise, it dumped out another cup or so of liquid. Will fuel mix with oil to make an amber colored liquid that is thin like fuel but leaves a residue like oil? There are only 2 tubes that run into the air box, one comes from a device that splits into 4 tubes that connect to the engine just below the ehaust pipes. Im guessing this provides suction or pressure? The other tube comes from a block like shape that is part of the head of the motor. Is this an oil overflow or something?
I pulled off the tank and had it running, I sprayed some starter fluid into the intake when it was starting to run a little low on the RPMs, didnt seem to change anything. So i pulled off the filter and tried to start the bike but couldnt get it to stay running and spray it in the box at the same time. So i sprayed a half second spray into the air box then tried to start it but it didnt seem to change anything. Maybe im doing something wrong here or is this pretty simple?
One other thing I did do was i decided to drain some oil. I set it up to drain slowly until i saw the line come down. Well i filled about 2 cups worth of oil, and dropped the plug and spilled a bit more oil DOH! I plugged it back up and got the bike to run. It ran for a few minutes and the problem surfaced and the engine died. The bike straight upright on the rear stand. I looked at the window and it was still above the full window. When i put the bike on its kickstand i noticed the fuel was just about the F line. I guess this could be two things, either the oil isnt circulating or there was way too much. I watched the window as it was running and saw the oil churning and whatnot so the oil seems to be moving about, so im guessing the oil is circulating.
The engine didnt seem unusally warm after the time it was running.
I checked the air box drain hose one more time and found that it hadnt filled up while working on it/running it.
I havent checked the battery, but i dont have toold to check electrical stuff.
Im starting to wonder if the shop messed something up on the bike. I know they put the flanges that connect the exhaust to the engine on backward.
Thanks for all the ehlp and patience so far.
Premium Member
I'll go look at the hoses you mentioned a little later and try to help you there. For now, lower the engine oil level to the full line with the bike on the centerstand. Sounds like it is overfilled.
Update.
I think we have enough information now to make a confident diagnosis! :mrgreen:
While you probably should go back to "Std." plugs, that's not the source of the problem.
ALL of the symptoms you relate points to the bike running VERY rich, to the point of flooding out. Black soot on plugs, gunk in air box AND over-filled crankcase (because GAS is getting in there!!!!) and the fact that ether doesn't help when it stumbles (because it has too much fuel already).
So, it's back to the carbs and more specifically the floats and the needle valves. Either: one (or more) of the floats is not "floating" any more OR the adjustment is way off OR the needle valve is not closing off the flow of fuel like it should.
This could be combined with a petcock that is not shutting off the fuel when the engine is off. If you have a manual OFF position, you are using that when parked, right ???
CAUTION: Do NOT run the bike more than a few seconds until you change the oil. The old oil is contaminated with fuel and is not lubricating as it should. You might then have to change it AGAIN after you get the problem solved.
And last but not least, you might be able to identify which carb(s) are in trouble by looking at ALL the plugs. Hopefully only one will be black and sooty or one will be a LOT worse than the others.
1 - 20 of 32 Posts
