Does anybody know where the horn is placed in Burgman 400 (2004) ?
It doesnt work anymore and i need to check if it is the horn button not working or horn itself. Any ideas how i can test it?
Thanks
Once you find it, if you push the button and voltage appears at the horn and no sound comes out, then it's bad.......unless there is a wire loose or broken.
It probably is mounted in the body panels covering the front forks.
