Hi I bought a old Suzuki GS850, someone put pod filters on it and tried to compensate by changing the jets and they went way overboard so it barely runs because it's so rich. I haven't checked if they shimmed the needle at all yet but I'll get into it.
I need to know what size the stock jets are in these carbs so I can go from there. Anyone know? Also what about the air jets on the intake side? They're currently 190 air jets idk if that's stock or not.
Usually when adjusting for pod filters I would just raise the needle up a notch and get some more fuel to the pilot circuit and it's good to go, but I need to know what the stock sizes were to start from. Thanks for any help
Try the parts sticky in the mechanics section... an alternative is see if there is a specific forum for these...would probably cover several models such as the GS750 that or try a Suzuki dealer....probably unable to help though. Good luck...just had another thought....try carb microfiche or specific carb dealers
