What seems to be the problem?
Go to "My Profile" (top right corner of the page), then click on the tab "About Me". You should find the Signature option there, along with an icon of a pencil to edit your signature.
Voila!
He has a sig. set.
He also has the "show sig" item set.
I don't know what else to do.
I can't see the Admin. setting to see if the "allowed sig post count" has somehow gone WAY up.
I think this should be referred to the Admins.
I will try to do that.
Administrator
I've messed around quite a bit trying to figure out the problem here, and I'm stumped. I'll be forwarding this thread to our IT guru for a look...hopefully he can fix this.
Administrator
I got a reply from Kris, our IT wizard, at around midnight last night! He finally found a deeply embedded plug-in, which has been here since before we took over the site, which prevents signatures from appearing until a new member has 25 posts! Since your sig is already set (I've confirmed that much), once you cross that threshold, your sig should just appear!
