1 - 17 of 17 Posts
· Happy-ass Lunatic
The proper tool makes all the difference!
I'm in the middle of a chain/sprocket swap. The front (countershaft) sprocket was on there tighter than a turtle shell (we all know they're waterproof, right? ;-) ). I put the breaker bar to it: nothing. I almost flipped the bike over. So, I borrowed my buddy's impact wrench, hooked up to the air compressor, fired that bad boy up to about 125 psi and let 'er rip. A piece of cake. The proper tool makes all the difference.
Next, I had to cut the chain. Hacksaw, anyone? No thanks, I have borrowed my dad's Dremel tool, thankyaverymuch!! 30 seconds later, the pin head's completely gone and I'm ready to extract it from the chain. The proper tool makes all the difference.
Needle-nosed pliers and vice grips, Mr. Landry? No thanks, I've got my Motion-Pro Chain Breaker/Riveting set. That should do nicely. 3 minutes later, and I'm enjoying a nice cold Budweiser, looking at a pile of parts. The proper tool makes all the difference.
[SIDEBAR: I got the Motion-Pro kit for $69.95!! $78 shipped to my door . . .took 2 days. What a deal!! http://www.tucmoto.com/Merchant2/merchant.mv? ]
The proper tool makes all the difference in the world. I gotta' go buy me an impact wrench and a Dremel tool (yes . . . I'm the ONLY person on the planet without a Drememl to play with :roll: ).
My sprockets and chain were in poor shape and it's all my fault. :-(
For starters, the chain stretched out a month ago and I kept riding it with the adjustments all the way against the stops. Then, I made the mistake of riding it hard in this condition. My biggest mistake was that I didn't torque the rear axle when I replaced it after getting my new tire. That's right . . . I'm too stupid to torque one of the most important parts of the bike. :banghead:
So, I'm out riding . . . with an improperly-torqued rear axle . . . with a stretched-out chain . . . hitting it fairly hard in a left-hander . . .when I hear (and feel!!) a series of sickening "clunks" coming from the rear end. I knew it was the chain. I pull over and there's metal filings all over the rear of the bike. Ouch. I limped on home and started tearing it down.
The improperly-torqued rear axle allowed the rear wheel to move under the stress of the cornering, thus mis-aligning the sprocket at that point. The loose chain did it's own thing, which was basically to barely stay on the sprockets and chew off the inner-third of each tooth on the rear.
The front sprocket teeth looked like shark fins.
Maintain your chain. <=== That rhymes!! :mrgreen:
<. . . and use the proper tool. it make all the difference.>
[EDIT: I'm so @#$%ing giddy, I'm going to do my valves next. It's been, uh <censored> miles since they were last adjusted by the dealership. I think I'll order a gasket kit and plan on doing them before my trip to Arkansas on the 21st with "madmotorcyclist," a member of another forum who has become a friend of mine. He lives over there in Jonseboro, AR. He is, without a doubt, the youngest 60-something I've ever met. A good rider, an excellent ride leader, and a hoot to hangout with. He rides in that zone of "fast enough to have fun, slow enough to stay alive." Anyone want to join us for a spirited ride up Crowley's Ridge from Forrest City to Missouri on May 21st? It'll be a blast!]
Man, I thought everybody on the planet got Dremels years ago!
I finally fried mine after having it for about 3 years and using it on everything under the sun. I had a very nice digital one, now I can't find another one for the life of me :(
Good to hear you at least had access to all the tools you needed, though, it does make life much easier. I had to replace a wheel bearing on my Fiero a couple years back and was having some trouble getting the axle nut off, and I didn't have access to an impact wrench. That took a long time and a whole lot of energy :(
Dremels are nice. The other night I was putting a light bar on my wife's Intruder. The kit came with the turn signals so I didn't need the OEM turn signals and needed to take them off. They attached to the fork tube with a one piece bracket that tightens with an allen bolt. Rather than disassembling the forks to slide the bracket off the fork tube, I used a Dremel and cut the bracket. Made a 5 minute job out of one that would have taken an hour or more.
Many thanks to Mr. Dremel.
Yeah, Dremels are great. Have to get one someday.
As far as an impact wrench, I'd never use one enough to justify the cost of it and associated compressor. However, there is such a thing as a manual impact wrench. I bought one for around $50. It's slower, certainly, but for the few times I need impact capability it's fine.
· Happy-ass Lunatic
Discussion Starter · #6 ·
md2lgyk said:
There is such a thing as a manual impact wrench. I bought one for around $50. It's slower, certainly, but for the few times I need impact capability it's fine.
Do tell. Is it one of those things that you hit with a hammer, and the action of the hammer makes some internals rotate the piece off? Awesome.
I'm googling that one!! :mrgreen:
<i love how the part about my stupidity and lack of maintenance was totally sloughed off in favor of a dremel discussion!! :mrgreen: >
I second (or third) the comments on the Dremel...I have one and it has been so good to me. That and a power inverter saved my a$$ when doing some work on the stereo on my truck.
Yes, that's what I'm talking about. Mine came as a set with some sockets and screwdriver bits. I bought it nearly 20 years ago so they may be more than $50 now. You'll also probably have to go to a "real" auto parts store or tool supplier (not AutoZone or Pep Boys) to find one. Harbor Freight may also have them.
Maybe we were just being nice. But, for me, I'd much rather talk power tools, ar ar ar grunt snort scratch....
Folks say Shaft is a bad mother .. shut your mouth, just talkin' 'bout Shaft.
1 - 17 of 17 Posts
