Greetings all: I removed my throttle cables to lubricate them but now that I've reinstalled them I am no longer getting the throttle 'snap-back' when I turn to the right. A course of action how I can go about correcting this would be highly appreciated
Too tight at the adjusters near the throttle would be my guess or poorly routed/pinched cable/s. I assume you popped the cables off at the throttle end...Make certain the cables are not nylon lined as lubricating these can cause the lining to swell. Also check the cable trunnion is not twisted where it fits into the throttle as this will put a twist in the cable. Also make sure the cable is not crimped at the throttle or trapped in the housing in any way.
