After not riding at all last season due to some surgery, I'm making up for it this season, and loving every minute of it. The bike (2005 S50) is running great and I'm still loving it.
Onto the issue. Briefly, On a recent rider with my brother, he noticed that when I use my turn signals, the unused one has a faint pulsing/dimming action. Not enough to confuse which way I'm turning, but still noticeable if you look for it. And the other day when I was riding alone, I noticed my signals went to that fast blinking mode during one of my turns. It did it only once or twice during the ride, and went back to normal by the next turn.
Anyway, when I got home I checked all the bulbs and they are all fine. And that's the extent of my comfort zone when it comes to bike electronics. Also, I had replaced the horn a while back with an aftermarket one (no relay required), and I even disconnected that to see if it made a difference. It didn't.
Other than that slight pulsing of the off side signal, everything seems to be fine and the bike starts right up without hesitation and rides nicely. Before I swing by my newly-found mechanic and pick his brain about it, I figured I'd check with the brain trust here on the forum. Anything else obvious that I should look for that I could try without potentially making things worse?
Thanks.
Thanks.
