Hey guys. Just replaced my fuel pump on my 2003 Victory Vegas. Upon changing it out I ran into a little rubber piece on the end of the fuel pump that I can’t seem to find anywhere. If anyone would happen to know where I could find it or even the name of it it would much appreciated.
39664
What does that piece DO ?
Do you really need it ??
I mean I would assume you need it since it’s there. It goes on the end of the fuel pump (nipple) and then into the assembly that the fuel regulator is attached to. I’m assuming this piece creates a vacuum or is used to build pressure. I really have no idea.
I'm not getting it.
Does it connect two pipes together.
That is, does something flow through that piece....be it fuel or air ?
If so, you should be able to fashion a replacement with some hose.
