Recently removed the baffles on my 06 s50 Suzuki not knowing that meant I would have to retune the carbs. It is popping when decelerating does that mean it's running lean? What should I do?
Well you wanted noise......and now you have it.
Yes, that means that the "low speed jets" in the carbs are too lean BUT they are not adjustable enough to fix the problem.
So......you need to just live with it OR get some baffles back in the pipes.
Do you still have a stock intake ? Changing that can cause the popping too.
Increasing the idle speed might help a little.
