Need help! I bought a 2007 yamaha vstar and there’s no ignition switch into it. I tried to connect the red and brown wire and it switched on. Engine cranks but there’s no spark and also noticed that the fuel pump doesn’t turn on or does it supposed to be? I already checked side stand switch, neutral switch, kill switch, fuses, stator, ignition coils, battery is good, solenoid, fuel pump starts when i connect directly to a 12v, relays are good. The only thing I haven’t checked is the ecu which i find complicated. Can anyone give me some advice on what to do? Thanks
