Hi to all.
Just joined recently got vz 800 marauder in the paperwork that came with it was a list of recent work that said o ring perished allowing fuel into motor can anyone tell me what o ring it is .
Thanks in advance.
An 'O' ring is a rubber or other soft material round profile washer type seal of varying sizes. It usually fits into a recess to form a seal between two surfaces. Often found between two parts of a pipe or other sort of inlet or outlet.
Discussion Starter · #4 ·
Hi to all.
Thanks in advance.
Firstly I want to apologise think I put this message in the wrong place.
Cheers for the replies I do know what o rings are I may
Hi to all.
Thanks in advance.
:ROFLMAO:
His question was not "what is an O ring".......but which one they changed.
He needs to ask the people that did the service.
Hi Easy rider you are correct trying to find out which o ring would allow fuel into the crankcase? and apologies think I put this in the wrong place
