Hi all.. noob here.
Did a oil change first time, and did two mistakes, how to correct the same.
1. Over filled the oil, is max now. Should I drain it a bit?
2. I forgot to change the filter , Can I change the filter without draining the oil first?
What exactly do you mean by "is max now" ?
If it only comes up to the top mark on the dipstick (full), it is NOT overfilled.
And unless the oil was REAL old before you changed it, just run it and do the next oil and filter a bit early.
Many brands actually recommend changing the filter only every second oil change anyway.
