Points gap...set to specs, timing...points should just begin to open at a predetermined BTDC...usually marked on the points backing plate. Check the points for arcing...they will be black and pitted if they are arcing. This is usually caused by the condenser/capacitor failing. Finally check the plugs/caps/cables/coils.
good luck and post if you need more help.
