Automotive tire Automotive lighting Bicycle part Automotive design Rim
This is a 2007 yamaha xvs1300A, anyone knows where this goes? I bought this motorcycle without an ignition switch, i cranks but no spark. I checked fuses, diodes, relays, switches but still no spark and fuel pump does not prime. Will it be the ecu needing a matched keys? Anyones help much appreciated. Thanks
Administrator
As far as the fuel pump goes, have you checked all the fuses? Can't help you with that connector.
Yes i did check all the fuses and relays, i even removed wire harness to check the continuity of every wires and all is good. I think having no proper ignition keys is one of the reason and maybe the ecu might be damaged. What do you think?
You NEED to find how that ignition system works.
Some need to "see" a simple resistor inside the switch to activate the ignition module.
No resistor, no start.
Administrator
I think you are going to need a wiring diagram to figure this out.
