So I think my clutch has gone on my xvs400, when it's in gear it still rolls freely has anyone else had this problem?
your rpms increase but you dont go any faster. the clutch usually has two adjustments at the engine the rod needs a quarter turn of freeplay and at the handlebar the lever needs about an eighth inch of free play.you need to check your manual for how to adjust the cable at the engine.
Check your chain rollers at the engine point. Maybe you have a broken spline that connects the pinion to the gear drive shaft. I had that problem and thought I'd done the gear box.
